go to http://www25.brinkster.com/fletchlinks/napa311/index.asp
and download the TMPGEnc templates for NTSC\PAL whatever you use and load the templates, encode the movies and walla!
This will work for NAPA DAV-311 portable vcd\mp3\cd player![]()
Results 1 to 1 of 1
video that has pauses in it. is there a way to fix things?
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2011, 08:45 -
Converting a Final Cut Pro Motion template to a DVD Menu...
By Huntr777 in forum MacReplies: 0Last Post: 4th Apr 2010, 13:48 -
Fast fix
By ingeborgdot in forum Newbie / General discussionsReplies: 9Last Post: 5th Sep 2008, 12:09 -
Is there a jerkiness (motion detection?) setting in CCE?
By robrosen in forum Video ConversionReplies: 0Last Post: 20th Sep 2007, 17:42 -
Bad NTSC to PAL converstion - jerkiness. How to fix?
By PTRACER in forum Video ConversionReplies: 34Last Post: 11th Sep 2007, 18:00
