I was wondering what software people are using to covert NTSC video on their computer to PAL video. I made a few DVD video's for a few weddings in NTSC format to show here that I need to convert to PAL format to send over to Europe. I have either the MPEGS or the AVI files to work from so I don't have to work off of the DVD's.
I have read about Canopus Procoder, but it is kind of steep for my budget at this time.
Thanks for the help and advise,
Dezine (Michael)
http://forum.vcdhelp.com/viewtopic.php?t=100965&highlight=
Look for my post.... -
find out if the PAL DVD player that will be used to play the DVD's on will play NTSC discs first. a lot of them can. if it does, you've saved yourself a lot of encoding time
MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free
Can VCL software convert NTSC to PAL?
By bobvideo in forum Newbie / General discussionsReplies: 5Last Post: 7th Nov 2011, 12:37 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Software Recommendations for converting 1080p HD clips to SD NTSC or PAL?
By seville63 in forum Video ConversionReplies: 2Last Post: 27th Mar 2010, 09:04 -
Need software that identifies PAL/NTSC
By djkilla in forum Software PlayingReplies: 5Last Post: 20th Jul 2008, 19:03 -
PAL->NTSC ripper software?
By coody in forum DVD RippingReplies: 4Last Post: 8th Oct 2007, 23:50
