im tring to get my blade2 divx to play on my dreamcast (www.dcdivx.com)
but i need it to be mpeg layer 3 to play but the avi file i have has ac3 audio how do i convert
Error: The requested audio compression is not compatible with the input format. Check that the sample rate and channel count of the input match those of the requested format
[has audio]
Codec: AC3-Digital
Bitrate: 438 Kbit/s
Channels: 5 (surround)
Samplerate: 48,000 Hz
[need audio]
MPEG Layer-3
32 Kbps
22,050 Hz
Mono
Does the Dreamcast really play Divx files, i thought that was a joke, i have the same Blade 2 Divx and i hate saying this as the sound on that thing is beautiful, but give this a try Open the Blade Avi up in Virtual Dub and select save wav from the file menu and give it a name.
Once thats done it will be saved as a wav, rename it so the file extension read ac3 instead of wav.
Now you need HeadAC3he and use that to convert the ac3 file to a proper wav, if you dont know how to use it get back to me, but mess around its not that hard.
Now open up Virtual Dub again and open Blade 2 again and go to audio and select wav audio add the headac3he wav and you now have the original video andd a wav soundtrack, now go to video and select Direct Stream, then audio and select Full Processing, the to compression select Mpeg layer 3 and click on the bitrate you want to use.
Now select Save avi and you will now have the same film but with an mp3 soundtrack, i know its fiddly, but its the best quality way i know of, let me know if it works, as im still dubious about the whole Dreamcast Divx thing, i though they barely played VCDs.
Just re read your post, what the hell are you trying, convert to VCD, preferably SVCD if you have a compatible DVD player, do you have any idea how good the sound is on that, most original DVD's dont sound that good the standard Dolby Digital bitrate is usually 384k.
Do you need that low a bitrate your gonna make it sound like crap, i have cam avis that would sound better than that
How to convert 5 ch. AC3 to 5 ch. MPEG-2 Layer II
By macman241 in forum AudioReplies: 21Last Post: 1st Sep 2016, 11:08 -
VirtualDub: Layer Filter
By creamcone in forum EditingReplies: 6Last Post: 26th Dec 2010, 11:27 -
No 48kHz options in MPEG-Layer 3 in VirtualDub and Mod
By ashwin.terminator in forum AudioReplies: 24Last Post: 6th Apr 2009, 14:07 -
Encode mpeg-1 layer 3 in AVI to AC3 surround in Nero Vision Express 3
By jimbojr in forum AudioReplies: 0Last Post: 18th Feb 2008, 19:51 -
Mpeg-1 Audio Layer 2 - Audio Tag 50 - VirtualDub, TMPEGEnc Can't Read
By Rebooter in forum AudioReplies: 2Last Post: 26th Oct 2007, 21:51
