I have got some problems ripping Gone In 60 Seconds. I can rip the whole movie and get it work on my hdd. But when i am going to record it, it says that my VIDEO_TS folder is too big.
When i start the movie a trailer of High Fidelity comes up! I have tried to delete this trailer but it wont workCan anyone help me?? I want to delete the trailer..how do i do?
And another question... Can i buy DVD+R discs that are bigger than 4,7 GB and burn?
/ Voppe
I done the region 2 version..which is too big to fit on 1 dvd-r
i used smartripper..just keep the main movie and your chosen sound want you want and demux both of these to separate files and then in spruce up convert to vob and then burn to disc and it will fit.
follow guide here and it should help you.
http://www.dvd2dvdr.com/ -
at this point in time, you can't buy a disc bigger than 4.7gb..
you can buy double-sided dvd's which give 4.7gb on either side..
delete sound between x seconds and y seconds?
By charlieship in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2011, 22:14 -
Problems ripping Precious
By carlos28355 in forum Blu-ray RippingReplies: 7Last Post: 16th Jun 2010, 20:54 -
Ripping Problems
By pepegot1 in forum DVD & Blu-ray WritersReplies: 4Last Post: 23rd May 2008, 08:15 -
Problems ripping this...
By EliteMarine in forum DVD RippingReplies: 7Last Post: 29th Apr 2008, 22:18 -
Having ripping problems
By ezzye23 in forum DVD RippingReplies: 3Last Post: 25th Jun 2007, 12:30
