When i put the DVD in in says there is no aspi driver and it cant read some files, you can either click ignore or abort or retry. My settings are the same as in the guide on this site and this has never happened to me before. but now it happens with every DVD i try!! help
thanx
I d/l the driver and unzipped it but it still says no aspi driver. I got the correct one. When i click the install folder it says hit any key to continue and nothing happens and the screen goes away. is there another program i need?
If you're running windows XP, try getting FORCE ASPI, its the only ASPI that has worked with my Windows XP Pro
Mojo
tmpgenc authoring 4 + smart rendering problem
By themaster1 in forum Authoring (DVD)Replies: 1Last Post: 3rd Sep 2011, 23:14 -
h264 smart render problem
By wentwog in forum EditingReplies: 2Last Post: 18th Aug 2010, 15:26 -
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 17:48 -
problem with the ripper
By chuky in forum Newbie / General discussionsReplies: 2Last Post: 28th May 2007, 13:15 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 02:15
