OK, I want to try copying my home VHS tapes to DVD, using a ATI 7500 AIW card but not ATI's capture software.
I want to use Ulead's DVD MovieFactory, can I just use Ulead's template for DVD at high to capture?
Also do I need to do anything after the capture before burning to DVD, or is the captured file ready to be burned with nothing done? I ask cause I do not know if I should worry about deinterlacing or inverse telecine.
If you see the video looks scratchy then I would deinterlace, but if they look good you may not have to. If the template capture to the DVD video standard, it will have no problems.
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
