I have ordered my first dvd recorder, a Panasonic DMR-E30k. This may be a dumb question, but here goes. I have seen on this forum that a dvd disc takes up about 1/3 of the storage space as a vhs tape. My question is can you record 12 hours of vhs tape onto a 4.7gb disc in the non timer mode. Thanks
DVD is not limited to a set bit rate.
http://www.vcdhelp.com/dvd.htmAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
The 1/3 storage space you are referring to is physical storage space. I have a Panasonic EM-20 and the most I can get on a disc is 6 hours in Extended Play mode.
In order to put more video hours on a disc you need to drop the bits per second and thus the resolution. There will be a point that you do not want to fit more vide because it will look so poorly that is far worst than VHS, and that would not be progress but a misuse of new technology. The quality will depend on the encoders you use MPEg1/Mpeg4/Mpeg2, the source of video, and the bits per second. It's up to you were you draw the line between quality and hours of video on a single DVD.
Most people that I know will stick with 2hrs MPEg2 DVD and a few between 3-4hrs, beyond that it looks like crap to most.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
