  1. hello
    i want to capture images from my sat reciever via the input video composite...this works but where can i input the sound from my sat reciever ?
    my pinnacle card only has a line out audio with a short cable to the soundcard 'line in'
    i don't see an line in audio on the TV card ??
    thx 4 reply
    Guy
  2. WHOOPS!!!
    error on my part
    I'll check how I've got it here and post back
  3. http://www.geocities.com/cryptkeeper22002/connections.jpg
    get 2 Y splitter cables - female rca to male rca
    regular male to male rca cable(which you should have already from your sat)
    and a rca male to headphone jack(the small one - which will fit into the line in of your sound card)
    if you got any questions let me know
  4. ok Cryptmaker
    i figured it out , thanks ! it works ! but the images i caputure are so very big ! ( in MB )
    what is the normal MB of a movie captured in .AVI ?
    or do i better record in MPEG ?
    thx for your time
    Guy
  5. it all depends on what you're planning to do with the capture
  6. well...i want to capture movies and then burn them in VCD ...
    Guy
  7. from what I've read in a few threads here
    some capture to avi(uncompressed) then convert that to mpeg
    reason is that the quality will be very nice in the avi
    tho I capture directly to mpeg-1
    and then split the file
    if it's too large for 1 cd
    settings for my capture are
    mpeg-1
    352x240 resolution(NTSC)
    224kbps audio
    29.97fps
    1150000 bitrate or closest to it
    Feb 2002
    england
    hi,
    use virtualdub to capture, and compress the video as you are capturing depends on your pc.
    i have an old p3 450mhz and capture avi through my rave card at about 14meg/minute(audio is pcm thats why the size is so big)
    http://forum.vcdhelp.com/userguides/89899.php
