Hi all,
I use VCDEasy but I liked the way of Philips VCD toolkit.
Do you have any advice on a commercial authoring software? With no skin looking if possible... For the moment, my choice would go to Ulead's DVD workshop.
By commerical , do you mean for professional presentation quality ? DVD Workshop is pretty good program, for home use to semi advanced, but it's no way a commercial product. They have predefined templates that make DVD creation pretty easy, but unless you make your own in Photoshop, the templates are limiting. Still not a bad package, but I highly reccomend the 15mb patch for the program to get stability, as version ( unpatched ) is not too stable and prone to crashing. The patch also clears up the audio synch issue that both DVD Movie Factroy and DVD Workshop suffer from.
For me, "commercial" = software in box.
I tried DVD workshop 1.2 but I've been disapointed somehow. I can't say, but there's something missing. I'm not convinced by the interface and I didn't find if it's possible to have multiangle scenes. Maybe I miss the "flow" representation that exists in VCD Toolkit.
I also tried VideoPack 5, and I've been even more disapointed. For the price they ask... I found it way too simple.
Turbito, have you set your menu as first item in the VCD tree?
DVD rental software (non-commercial for internal usage within company)
By PushPull in forum Newbie / General discussionsReplies: 11Last Post: 16th Nov 2011, 11:20 -
DVD authoring failed, advice?
By Elevenius in forum Newbie / General discussionsReplies: 12Last Post: 8th May 2011, 14:06 -
Automatic Commercial Removal Software
By bingmel in forum EditingReplies: 26Last Post: 24th Oct 2010, 19:00 -
Interactive DVD Authoring Advice please
By Arron in forum Authoring (DVD)Replies: 1Last Post: 26th Apr 2010, 07:48 -
Need advice on authoring a dvd lens cleaner disc
By JeffSVI in forum Authoring (DVD)Replies: 3Last Post: 7th Sep 2007, 09:09
