Results 1 to 10 of 10
  1. Hi,
    I am currently in the market for a new soundcard. Had to give up my old one due to issues with my system.
    I have a 1GHz AMD on an Asus A7V-E mobo. For a vid card I have an ATI All In Wonder 128 Pro 32MB. I do mostly TV captures but am getting into Home video editing. I currently do not have a DV camera, but hope to soon.
    I was hoping to get some feedback and suggestions from people in this forum as they probably know best the ins and outs as it pertains to video work.
    I have been seriously looking at the Hercules Game Theater XP, it's breakout box is great.
    Thanks for any and all assistance
    MDK
  2. i've got an aureal vortex2 SQ2500 i'm very happy with, though the company went out of business so i don't expect many win2k driver updates... but the sound quality is very good, plus a digital output is always a plus.
    but i've also heard great things about the Turtle Beach Santa Cruz, (though i don't remember if it has a digital input, which i'd like on my next card). turtle beach has always made top quality stuff, so it's probably hard to go wrong with that.
  3. Hi patrickm,
    Thank you for your response. I too am interested in having a digital input on my next soundcard. I just checked and it appears that the Santa Cruz only has an internal digital input. The card I had to ditch was a Montego, my system had issues with the A3D chip. I agree that Turtle Beach makes some quality stuff and if the Santa Cruz had an external digital in I would consider it very strongly.
    Thanks again and keep them coming
    MDK
    Jun 2001
    st. louis, mo, usa
    i have a sblive1024 with an addon digital io card by http://www.hoontech.com it's great. coax and optical io.
    if i were to replace mine, i would probably replace the sblive with an sblive 5.1 to take advantage of mpeg5.1 audio....i believe it will decode it.
    i'd still keep my thirdparty addon card though
    THIS IS HARDCORE
  5. [double post]
    <font size=-1>[ This Message was edited by: patrickm on 2001-08-08 09:11:58 ]</font>
    Jun 2001
    st. louis, mo, usa
    i have thought about that... a dedicated dvdplayer/divxplayer/vcd/svcd/mp3/EVERYTHING player.
    all you need is a decent processor, a decent soundcard, and a tv-out.
    the coax i/o.... im not sure if it's ttl, but i assure you that the interface is identical to coax digital i/o on receivers and dvdplayers.
    i don't mean 75 ohm coax...i mean rca
    THIS IS HARDCORE
  7. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    is it a coax-level digital in or a TTL-level digital in? if it's coax, it's a trivial thing to run an external jack to it. all you need is a short piece of wire, a drill, and a $.50 RCA jack from radio shack. if it's TTL, that's essentially the same as a Toslink optical connector. with a few bucks (like $15 you could get a Sharp toslink receiver chip that exports a TTL level signal).
    MPEG-5.1 would be nice though.
    someone (PCChips?) is making motherboards with a 6 channel onboard thing and a $20 digitial IO daughtercard. in some sense it might be cheaper in the long term to just make a separate computer with a duron as a home theater digital component, for recording off CDs, being an MP3 jukebox, etc. because even if they implement whatever CD copy protection they want, it better play over a digital connection without errors, and with 'old' recording software/hardware it really couldn't stop you even 5 years from now.
    on a semi-related topic, does anyone know where i can get an older (slow) CD-ROM with a TTL digital out and a play button? i have two cd-rw that work (just a resistor and an LED and you have a toslink) but one is my new burner and one has no play button. my cheapo cd-rom doesn't output a legal digital out signal (like 2.6Volts or something). but i'm interested in making a mini standalone cd player for my other room. (and the analog audio off a cd-rom is terrible, but digital is digital)
  8. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    well, i'm not quite sure what you mean, i was talking about the internal jack on the santa cruz, whether it expects TTL or SPDIF-Coax voltage levels.
    TTL=electrical equivalent of Toslink optical 0=0V, 1=+5V
    SPDIF-coax: 0=-.5V, 1=+.5V, (@ 100ma or something)
    TTL is usually run inside computers, and coax on 75 ohm RCA cables.
  9. If you want to also look at a new system (something I have been thinking of doing for my entertainment system) you may want to look at this.
    http://www.tigerdirect.com/email/mil127.asp
  10. Thank you for your responses and comments.
    I think for myself I would prefer to get the digital in factory built (already a part of the card). However, I do like the Santa Cruz card. Still have many reviews and opinions to look over before I make a choice.
    Thanks again
    MDK
