hi - i just converted my wmv file to mpeg with tmpgenc. however, i noticed that sometimes, it's fuzzy when there's action and the quality is not as good as i would like it. is there a software that i can use to spruce up my mpeg file to a better quality? thanks.
re-encoding will always let you with a less quality product.....
sometimes, its not really obvious but sometimes, it is.......
Always start with the best encoding you can, then re-encoding will maybe "enhance" a little some points, but no guarantees....
Assure yourself that you have a defragged HD and that you are working on your fastest HD for encoding and editing jobs....
Bonne chance!
"OO"
ps:you can try Panasonic 2.51 or LSx3 encoders..... will take you a long time to encode but make tests...P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo
Need help improving the quality of this anime
By Luminous69 in forum RestorationReplies: 11Last Post: 17th Jun 2011, 19:00 -
Improving quality?
By BwanaP in forum Video ConversionReplies: 30Last Post: 19th Jan 2010, 22:03 -
Improving video quality
By rusting in forum Newbie / General discussionsReplies: 10Last Post: 10th Jun 2009, 00:35 -
Improving Video Quality
By pctech@apc4me.net in forum Newbie / General discussionsReplies: 2Last Post: 30th Mar 2009, 18:39 -
Improving quality of mpeg before converting to dvd...
By AshleyQuick in forum Newbie / General discussionsReplies: 4Last Post: 28th Apr 2008, 14:41
