I have a DVD burner and am converting VHS and laserdisc to be burnt on DVD. I have tried using my Gainward Ti/500 Vivo card but have to convert from AVI to MPEG2.
I think my best solution is to get a card that will convert to mpeg2 in real-time.
There are so many cards out there. Please help me narrow the field down. Please be opinionated. Tell me whats good and what to avoid. Thanks!
P4 1.7Ghz, 512M DDR, 2 80G Maxtor 7200/133, Win ME.
your in luck i went through a few cards and by far i found fo r ease of use in mpeg 2 to be ati tvwonder ve goto ati.com and look at manual cuz youll need a couple audio cords to fit your sound card i record using win movie maker in win xp not sure what youll cap with but the card is cheap easy and grest!!!
No proc amp tv card levels controls in windows 7 vdub capture mode
By mammo1789 in forum Capturing and VCRReplies: 3Last Post: 19th Oct 2011, 08:20 -
Advice on capture card pci express or usb, for windows 7, umcpmpressed avi
By victoriabears in forum Capturing and VCRReplies: 12Last Post: 1st Aug 2010, 13:39 -
VHS/Beta Tuner MPEG2 from capture Card to Compress to Smaller File; HELP
By gauthijm in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2009, 09:05 -
TV Tuner / Capture Card - WinDVR 3 no Audio after Windows Vista install
By buzzsaw in forum Capturing and VCRReplies: 20Last Post: 12th Oct 2008, 15:06 -
A patch for Windows Media Centre Edition to accept any capture card?
By mikee55 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2007, 10:52
