I messed up. I did not know that you had only like 5 times to play diff region dvd's and the last region you play is the region it is locked on!
I did that and the last dvd I plyed was a region 3.
Has this happened to anyone? Is there anyway to bypass this at all? Or is it truly locked forever? Even with reinstalling windows and system restore, it's locked...can anyone help?
Don't know if this is considered warez but I used to use a program called DVD Genie, can't remember if that was the title but it's used to change the region on DVD-ROM drive an unlimted number of times.
Update: it is DVD Genie 8) and here's a link
http://www.inmatrix.com/files/dvdgenie_download.shtml
Update: NOT WAREZ, program is freeware
I personally haven't used the program in over two years and don't know what a current version may hold, but hey it's worth a shot better than your alternatives:
-live with region 3 discs
-playing with registry
-format and reinstall Windows and DVD software
-create second partition and install an OS such as Win 2000 or XP in order to install DVD software Hey do it five times and have a different region for each OS/partition and you'll have your very own region free setup Almost
[/i] -
Or alternativley upgrade/reload the drive's frimware... you REALLY have to know what you are doing though.
Region Blocked DVD Players?
By Nitro89 in forum Off topicReplies: 6Last Post: 23rd Mar 2009, 18:26 -
Terminology, Samsung BD-P1500 blu-ray region lock?
By safetyvalve in forum Newbie / General discussionsReplies: 5Last Post: 6th Dec 2008, 21:38 -
Multi-Region DVD Players
By zork152 in forum DVD & Blu-ray PlayersReplies: 17Last Post: 17th Oct 2008, 13:57 -
multi-region portable dvd players
By mech1 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Jul 2007, 07:36 -
Question: Region Free DVD Players
By SentaiFan in forum DVD & Blu-ray PlayersReplies: 2Last Post: 13th May 2007, 04:07
