Hello everyone
I've tried to do this, but I can't get! How I can do this?
I've read some guides at DVD Rip section of the website... and at Sefy's tells about CCE Plug-in (not standalone), but I don't find it, where I can download this?
See you!
The cce plugin is not free. If you want it you will have to buy it from Custom Technology or find it somewhere else.
I don't recommend using the cce plugin, the functionality of it is very limited and as a result its hard to get the same level of quality out of it as the standalone version.
Unless you specifically need a virtual dub filter run on your video than you should always frameserve with avisynth. With a dvd source its significantly faster and arguably has faster and better filters available for it. Also its much easier to use in my opinion. Here is the guide you need to use but this is the manual method, its much easier if you use the methods I describe below. http://forum.vcdhelp.com/userguides/78221.php
I strongly recommend you download and install the latest version of DVD2SVCD. For a very simple method just use DVD2SVCD with cce. It will frameserve and make all settings for you and the quality and speed will be very good. If you want more control over your encodes then you can setup your avisynth script manually but its still a good idea to install DVD2SVCD since it will setup avisynth and install some useful filters as well.
To create your avisynth frameserve script you can use a script generator such as FitCd or gordian knot. -
Originally Posted by adam
Because I want to do a VCD, not SVCD! -
DVD2SVCD uses avisynth to frameserve to cce. DVD2SVCD also supports vcd output in addition to svcds.
All of the advice I gave you still applies even though you are making a vcd though I would suggest you use a different encoder for mpeg1 (vcd) encoding. CCE is very fast but its mpeg1 output is somewhat lacking compared to other mpeg1 encoders such as TMPGenc or Panasonic mpeg1 encoder.
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 19:57 -
FrameServing from Vegas 9 to MeGUI
By Kit-10 in forum Newbie / General discussionsReplies: 8Last Post: 4th Dec 2009, 17:12 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 21:31 -
Frameserving with Adobe Premiere to Procoder?
By Soulman in forum Newbie / General discussionsReplies: 3Last Post: 19th May 2007, 06:01
