i have dvcII.. a sony hanycam dc-110e, windows xp, 192mb ram, 80gb 7200rpm hd, nvidia 61 mb.
i capture and produce my video using the dvd template, afterwards i convert it to .AVI using TMPGENC the reason for the conversion is that i would like to edit it using pinnacle studio which can only work with .avi files.. after the conversion . .and editing with pinnacle studio i convert it to vcd format using TMPGENC...
now the question.. am i doing this thing right? or is there a better way? a shorter way perhaps?
thanks in advance
What format are you doing the capture in? Is there some reason why your not capturing it in .AVi format in the first place?
moviestar 4.24 is the bundled software of my capture card (dazzle )
and i use it capture my video .. and i cant use it with .AVI as output
