I downloaded Korn's "Here To Stay" video, when I look at the properties of it, its in PAL format. It then plays on my DVD player, but its in black and white. On the computer though, its in color and looks fine. Unless I can convert it to NTSC format, I dont know what I'm to do.
If you know what PAL format is or what it stands for then please reply to this.
Gonna bring it down
Gonna bring it down
Gonna bring it down
Gonna bring it down
Gonna bring it down
Gonna break it down
Gonna break it! -
PAL is a format like NTSC. NTSC is mainly american while PAL is used I believe in the UK and Asia. You could try just to reencode it into ntsc. My player (Apex AD-660) works perfect with either.
Load it into TMPGEnc, then load a NTSC VCD template, this will convert it to NTSC. Sounds like your TV/DVD player wont play PAL, so you need to convert to NTSC.Originally Posted by Renegade5597
The PC will play both
Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
Video-CD NTSC (MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 10:40 -
Newbie : How to convert PAL into NTSC Format for Video Cassette Player
By kato2010 in forum Newbie / General discussionsReplies: 7Last Post: 11th Sep 2010, 11:40 -
I need PAL format help...
By jenn00_v in forum Newbie / General discussionsReplies: 15Last Post: 26th May 2009, 17:29 -
DMR-ES15 and PAL-N format video.
By goal in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Apr 2008, 00:59 -
.mkv contains PAL format video, I need it to be NTSC!
By kalii2 in forum Newbie / General discussionsReplies: 11Last Post: 17th Nov 2007, 05:14
