Hi there.
Since my last System-Reinstall I have Problems with VCDEasy (v.1.1.1.)
It is not possible anymore to burn more than one VCD file on a CD. Evertytime I try two or more files , this message appears in the Log:
"CRDAO Write
Cdrdao Version 1.1.5.
0,6,0: TEAC CD-R55S Rev.: 1.0 L
Using driver: Teac CDR-50/55 - Version 0.1 (data) (options 0x0000)
Starting write simulation at Speed 4...
Judging disk...
Skipping optimum power calibration in simulation mode.
?: Not enough memory.: scsi sendmcd: retryable error
cmd finished after 0.000s timeout 180s
ERROR: Write data failed"
I already updated my CD-R Software (now it`s the same Firmware as before the Reinstall, where VCDEasy worked without any Problems).
I guess, it could have to do something with the SCSI Controller? I have a AMD PCI SCSI Controller (from Tekram)... but now Idea where to find proper Drivers or so...)
Du you have any ideas how to solve this Problem?
Thx in Advance.
Lullmann
