  1. I have a few divx files that are 2CDs. I would like to merge them into 1. How can I do this?
  2. Member MaDmiZe's Avatar
    May 2002
    City of...Atlanta
    If you just want to stick two files together...There are many programs that will do that ..check edit section on the left.
    VirtualDub will join AVI's (it calls it append)....open first segment ...click on append...it asks for next segment.
    If you want to join then make joined (huge) file fit on one disc....it will have to be re-encoded at a higher compression ratio..TMPG will work or VirtualDub will work for sticking with avi.
