  1. I have a couple of SVCDs with very low audio levels. I'd like to convert them to VCD for a fussy standalone DVD player.
    Problem - I can't billy up the audio level.
    I'm converting the SVCD to a mpa and d2v. I don't have anything that will read an MPA to boost the gain, and TMPGEnc has been crashing when I convert the MPA to a WAV and then try to create a VCD from the resulting WAV file (or MP3).
    Suggestions? Thanks for your attention.
  2. take your mpa file and convert it to WAV with some sort of codec program, i use www.dbpoweramp.com
    then open up the WAV in a sound editor, normalise and save it, and open up TMPGENC, and re-encode the WAV into a VCD-standard audio file.
    then you should just be able to multiplex the 2 files together..
    Mark
    Swim with me
    And we'll escape
    All the trouble
    Of the present age
    Finally free
  3. Thanks for the dbPowerAMP pointer. Earlier, for some reason, I was getting crashes in TMPGEnc when I tried to get output from the d2v/WAV combo, but not now.
