I generated a menu image with VCDEasy from a .psd (Photoshop file). When I play the VCD in PowerDVD, everything works fine - The number keys play the appropriate videos, and they run fine, etc. The problem is that the menu has a big green bar through the middle of it. On my standalone DVD player, the menu looks even worse - It's not even recognizable. Any ideas? (It's a JVC XV-523 if that helps)
Oh, and I've loaded the menu mpeg file in WIMP, and it looks fine.
I'd recommend saving the image file as a bmp/jpg first, then making a MPEG still from it in VCDEasy. I haven't had any problems with it doing it that way. Do you have a specific reason for using .psd files?
Mojo -
I have had problems in the past when the image-mode was set to something other than RGB color.
In Photoshop have a look , it may be set to CMYK color mode.
There may also be extra layers in the image that are not needed and can be deleted.
Hope this helps..... -
Hi all,
I had a similar problem, except VCD stills were fine, and a few SVCD stills too, but all of a sudden, VCDeasy wouldnt generate SVCD stills properly any more. the file size of the SVCD stills is also smaller, around 55k, where the other stills i successfully generated (SVCD) were about 150k. this is with exactly the same quality settings as before.
i am baffled. tried to get the updated MJpeg stills version from the VCDeasy website but it was "temporarily unavailable" for almost a week now.
im gettin a little bit frustrated now! hehe
gavin -
Thanks for the help. Converting from a bmp helped on PowerDVD, but it would seem that my standalone player just flat out doesn't like VCD menus. I've tried pal, ntsc, 4/3 aspect ratio, no aspect ratio. Getting tired of wasting discs, so I'm admitting defeat to my player.
PowerDVD 10 - Blu-ray sound OK, menu navigation OK but no image
By rilopes in forum Software PlayingReplies: 4Last Post: 10th Aug 2010, 10:16 -
DVD Menu Image Buttons With Video Background
By sk8_aholic in forum Authoring (DVD)Replies: 3Last Post: 19th Nov 2008, 23:01 -
create a dvd menu from iso image
By DSLGuy in forum Authoring (DVD)Replies: 3Last Post: 19th May 2008, 09:30 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
Menu with image buttons
By lex1972 in forum Authoring (DVD)Replies: 5Last Post: 24th Nov 2007, 07:02
