i usually get my files from irc. they are usually 1 or 2 big files. but i just got a screener and it comes in like 70 small files. what do i do? i have no idea to start. pls, any advice is appreciated.
you mabye got one of those split winrar files... one of those files should active all the other ones and make one big file. you need winrar to do this but i dont know if that is the case.
it could also be a bunch of mpgs that have been split up. -
then there should be one rar file (and exe) that you can activate, and thatll create a big file from all the small ones you have.
If theres not an .exe file just click on the file r01 or r00 and click the extract box.
