  1. Hi board!
    Just wondered how I load a template for a VCD etc in TMPGEnc? I have the free version??
    Many thanks, stokefan
  2. After you open TMPGEnc look at the bottom right of the screen, you see LOAD, click on that. All the templates are stored in a folder call TEMPLATES, if it does not open you may have to find it, when you find it you can just LOAD the template you want to use. If you have someone else's Tempaltes be sure to load them in the same forlder, it just makes it a lot easier to find them.
    Aloha
    Bud
