I have downloaded a file that calls itself a VideoCD file, but it has an .avi extension. I can play it on PowerDVD but if I try to convert it in TMPGEnc, I just get a blank screen. It also has a funny fps of 14.985.
I am new to this, and was just starting to het my head around it all until this!
Grazer
See what happens if you change the extension to MPG. If it still plays fine, then it could be where ever you got the file it was just on the server as an AVI for some reason or other. If it doesn't play, then you likely are using an AVI file encoded with a very weird codec like MPEG V4 or something like that. Will the file load into VirtualDub? If so, check File | Information... to see what that says about it.
The weird frame rate sounds like a DivX file whose frame rate has been decimated by two. Basically, a 30/29.97 fps frame rate was cut in half resulting in 15/14.985 fps instead. Playback is still at 30/29.97, it's just that you see the same frame twice on each refresh or whatever because half the original data was discarded when the file was created. Most likely the original source was VCD, but this file you have is a highly edited AVI and isn't worth attempting to turn back into VCD.
HUN-YA!
Akai Rounin -
Thanks for the reply.
So are you saying that I can't burn this file to a CD to play on my DVD?
Grazer
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
How to convert an .avi or .mkv or .mp4 file to mpgav for burning to a VCD
By jasoothai in forum Authoring (VCD/SVCD)Replies: 8Last Post: 29th Oct 2011, 20:35 -
burning a dvd from an .avi file and a .wmv file
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2010, 07:06 -
burning mkv file and separate srt file to play on dual layer disc
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 12:26 -
vcd burning
By srckaimal in forum Newbie / General discussionsReplies: 26Last Post: 6th Dec 2007, 07:23
