can i a mod chip installed in mt PS2 from Game stop?
i didnt understand anything of hat post, if you mean if you can solder if yourself then the answear is: that depends on you you got som soldering experience? if you are getting a sbox/neo key its easy but its safer to give it to a store adn let thm do it, if you are getting a messiha wich is 40 wires+ then give it to a store
no what i mean is can i take my ps2 with the mod chip i bought and have someone at gamestop install it for me. But i passed by there already and they told me you have to have someone privately do that. I have no experience with this and dont want to screw it up. Where can i go to have the mod chip installed for me??
I think that mod chips are in that grey area with file sharing.
Stores don't want to be promoting "illegal" activity. THe game companies hate mod-chips and if they found out Jim's Store was installing them, they might pull their games from Jim's Store. -
fins some other store to mod it for you or just tell them you want to play imports
nation wide streos like GameStop, EB, Software Etc, and other nation wide stores will not install mod chips in your PS2..i suggest is going around ur area and find a import store which isint well known around the country and ask them in there if they install mod chips...if they do ur lucky....but if they dont sorry...then i suggest u hire somebody with soldering experiance maybe ur unlce or somebody u kno
Chip Choices and Raid Arrays
By Sckinhunter in forum ComputerReplies: 13Last Post: 30th Mar 2011, 21:02 -
The future of chip cooling.
By HotDamn! in forum ComputerReplies: 0Last Post: 11th Mar 2010, 03:00 -
Chip Resetter - Will it reset "auto" 3rd party CIS Chip?
By RBYoshioka in forum MediaReplies: 10Last Post: 10th Nov 2009, 16:49 -
How can I know what chip my DVD player has?
By kingfire in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Apr 2008, 07:45 -
Does the Toshiba HD-A2 have the Reon Chip or not?
By ofield1 in forum Newbie / General discussionsReplies: 1Last Post: 6th Mar 2008, 08:20
