Hi,
I read the guide on here to how to make a VCD and i found it really useful. I made a VCD and it works on my DVD player. However, the sound quality is jumpy and rather poor so is there anyway of stopping this jumpy sound as it can be very annoying when watching a movie. I know it could be anything from my DVD player or TV, to Virtual Dub or some other program i used.
Thanks for help.
Did you use TmpGenc to encode the VCD. If so ensure you install toolame as an external .mp2 encoder and ssrc.exe for re-sampling. This will produce better quality audio than Tmpgenc alone will.
How were you capturing the source? You need to record in stereo, 16bit, 44100hz sound. If you don't do this then TMPEGnc will convert your sound source to these specifications and often ruin it. If for some reason you can not record at those audio specifications, then run the sound through another program like Sound Forge to do the sudio conversion for you. It does a much better job.
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 21:10 -
Very Poor Video/sound quality
By mikey56hernandez in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2011, 20:27 -
Encoded BD movie sound quality
By GeeForce11 in forum Blu-ray RippingReplies: 0Last Post: 15th Dec 2008, 08:05 -
How to improve the sound quality of this video?
By awaisuk in forum EditingReplies: 2Last Post: 19th Nov 2007, 22:15 -
sound quality
By ecos in forum Newbie / General discussionsReplies: 10Last Post: 1st Jul 2007, 17:34
