Ok I'm trying to Copy Zoolander and all the extras etc but its over 4.7gigs, so I've Ripped the full DVD to my HD
Then I've used ReMpeg to shrink the main part of movie, this created a new Mpeg without any audio(is this normal?)
I then used DVD2AVI to RIP the audio from the main VOBs on my HD.
Now, do I use TMPGE to mux the audio wav file and video to create a new mpeg2 file with audio?????????????? <<< Will someone tell me if this is right so far??????
Now I need to convert this file back to vobs, but I've only got Ulead DVD workshop to convert , so I'd have to use a blank DVD-R as there is no option to convert to vobs to your HD,
Ok lets say I used a blank DVD-R once the information is burn't could I then copy the VTS files(on the DVD-R) back to the original folder where I first ripped the movie, obviously deleting the old MAIN movie VTS files, then could I use nero to burn the whole contents thus creating a DVD copy with all extras menus etc etc (perfect copy just with the main movie re-encoded at a lower bit rate)
Is this correct way to copy? would this work? do I need to do anything else?
Hi there, to me what you have described seems to be very long winded. Have you tried using DVDx 2.0 (freeware), with this you can rip the movie and it will automatically will convert it to MPEG1, I think by default. You need to specify the chapters first though. So you can have the movie and all the extras including subtitles if required.
If you then just want a VCD, just use Nero to burn the Mpeg file to CDR for you.
If you want Mpeg2 then use TMPGenc (freeware too!!) to encode the Mpeg1 file to Mpeg2 and burn away.
Hope that helps, by the way I'm no expert just a newbie!!
chrome ;0)
Oh forgot to mention that it removes Macrovision settings for you too. -
Chrome307,
If you want Mpeg2 then use TMPGenc (freeware tool!!) to encode the Mpeg1 file to
Mpeg2 and burn away
-Chrome307
Nowhere in Star-rats post did he/she even come close to mentioning VCD MPEG1 or MPEG2.
Chrome307 learn to read the ENTIRE POST and not make F'ed up Assumptions.
"Assumptions are the mother of all F^(k Ups"
-John Travolta in Broken Arrow -
If you used REmpeg to transcode the vob's then you created an .m2v file which contains no audio,it's the video stream only. You should use Ifoedit to remux the .m2v back into the ifo file in your ripped directory.
Got the message!! You made me laugh :0)
I didn't read his post or understand it, but hey you did and did you offer him any advice? LOL
chrome ;0)
Clown BD_BD Copier ?
By wulf109 in forum Blu-ray RippingReplies: 10Last Post: 5th Jan 2011, 20:33 -
What is the best video cd dvd burner and copier cd dvd
By nusratjaveid in forum DVD RippingReplies: 4Last Post: 30th Jul 2010, 16:13 -
Honest opinions about "Magic DVD Copier"
By _yo_wasup_ in forum DVD RippingReplies: 13Last Post: 1st Jul 2009, 15:58 -
FLOSS/Freeware all-in-one DVD copier
By danboid in forum DVD RippingReplies: 14Last Post: 18th Sep 2008, 18:21 -
RealNetworks to introduce a DVD Copier
By rcguy1 in forum Newbie / General discussionsReplies: 1Last Post: 8th Sep 2008, 09:20
