  1. Hi,
    Does anyone know of a utility that will allow you to send multiple AVIs to a DV Camcorder (Via firewire) on Win 98SE?
    I'm suffering from the 4gig file limit, and have to send multiple AVIs to my camera if the video(s) I create are longer than about 20 mins. The problem is: as soon as I send the second file, my camera rewinds about 20 frames - not to mention when I send the file to the camera - it starts recording +/- 5 or 10 frames too soon/ late.
    If there's a utility to "chain" all of them together, it'd save my sanity.
    Further info: I'm using Ulead Media Studio Pro 6.0.
    Thanks.
    May 2001
    Eric
    Well you can do this with Premiere by just putting the files on the timeline and using the output to tape function. You can output up to 3 hrs which is well beyond your tape limit.
    I haven't tested it, but I believe ULEAD VideoStudio6 will do the same thing. Put your separate files on the time line, then output to the camera.
  3. Scenalizer Live is a great tool for this, just select all files and upload them to the camcorder
    It's also a great tool for capturing (scene detection included)
    http://scenalyzer.com
    cheers
    Leo
    Equipment:
    Athlon 1700 XP system
    512 Mb RAM
    Geforce 3 Ti500 64mb
    1x 100 Gb hard disc (IDE)
    1x 40 Gb hard disc (IDE)
    1x 40 Gb hard disc (firewire)
  4. Thanks a lot for that Eric and Leo.
    The "timeline" option in Media Studio pro seems to create an AVI before going to tape (hence will still hit the 4 gig limit).
    But: Scenalyzer... wow! What an application! That did the trick (and a whole lot more).
    This app really should get a proper mention on this site.... it is to digital video capture what Virtual Dub is for Analogue capture.
