I am capturing video using my Fuji F601Z camera. It captures the video at 15 fps with 8 khz mono sound into an AVI file. When I use TPMGenc to convert to mpeg2 or mpeg1, the sound quality is poor. It sounds "tinnie" and noisy.
Let me tell you what does work to answer some obvious questions:
1. When I use TPMGenc with files from my DV cam (720x480 @30fps) the files are fine. The audio has no noise.
2. When I use virtual dub to extract the audio from my fuji files (15fps) the audio is fine.
3. I have used the audio file souce in TPMGenc as both the original AVI and from the virtual dub output. Both have the noise. The virtual dub one may be a little better.
4. I have looked in TPMGenc for audio input options and I cannot find any.
Any suggestions?
Is there any other mpeg2 encoder that I should try?
Matt
TMPGEnc has serious problems when resampling audio. I resample and normalise the audio in GWave before feeding it to TMPGEnc.
Thanks for the response.
What resampling settings do I use for mpeg2?
Where do I get gwave?Matt -
Ok, I did a search and figured out how to get gwave. Is there any other audio resampling programs? This one seems to be a bit of a pain.
Matt -
Sorry, should have said goldwave
http://www.goldwave.com
Settings...44.1k or 48k probably -
Thanks, Cloud.
I tried it and it worked!!
The audio is still not as good as the original wav file, but it is much better. I found that the higher sampling rate that I chose, the better the sound quality. Thus, I went with 96kb.
$40 sw. Ugh. But, at least the batch mode works well and it seems to be nice SW.
Thanks again.Matt
Audio quality very poor in 360p...but only on some vids. Help please!
By amb in forum Video Streaming DownloadingReplies: 0Last Post: 19th Sep 2010, 15:06 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
avi to dvd picture poor quality
By dwilson in forum Authoring (DVD)Replies: 2Last Post: 21st Mar 2009, 09:10 -
Converting .mov file to .wmv results in poor quality?
By zenfor in forum Video ConversionReplies: 2Last Post: 6th Feb 2009, 20:00 -
DVP5990-37.. poor avi decompression playback quality?
By Gareee in forum DVD & Blu-ray PlayersReplies: 6Last Post: 7th Jan 2009, 14:34
