  1. Ok, I did exactly as the newbie guide told me to to fit a large movie on to one cd. Everything worked great until I wanted to create the vcd using Roxio CD creator Platinum. When I add the file it tells me that I need to used a mpeg encoder to make the file compliant. It says that my system clock reference isn't acceptable: 1404. I have encoded the file using TMPGEnc. This only happens though when using the method the get the file onto one cd. Other files work fine that aren't using that method. The file is only 1hr 31 mins long. I have two of these files. Thats why I really don't want to use 4 cd's for this.
  2. EZCD Creator Plat 5 will ONLY allow you to burn compliant VCD discs. Meaning, you will be able to squeeze just under 1hr20min on an 80min disc. To do what you want, you'll have to use a different burning program.
  3. Ok, I got it now. Thanks for the quick reply.
  4. Will Nero let me do this?
  5. Yes, Nero allows non-compliant files to be burned.
  6. Thanks again. Nero did work.
