while capturing and converting directly to mpeg2 using Ulead or Roxio software and working with a Powerfull system. the program stop and locks the whole system needing to reboot.??? any ideas?
the theme of why you are not getting an answer to your question can be found on your other post
http://forum.vcdhelp.com/viewtopic.php?t=102620 -
Well, if you're using Ulead, that answers that question.
Try to reformat the drive, install WinXP, which seems to be the only OS that Ulead really supports, and then install a NTFS partition for capturing over 4 gigs. Ulead will only work correctly under certain conditions...
PC locks up playing WMVs
By slipkid in forum Newbie / General discussionsReplies: 9Last Post: 12th Jun 2010, 11:04 -
Hard to edit HD with powerfull computer
By Kashi169 in forum EditingReplies: 5Last Post: 22nd Mar 2010, 01:16 -
Recording to DVD from Direct TV's system of organizing saved programs
By sarainelkins in forum DVB / IPTVReplies: 2Last Post: 15th May 2008, 09:51 -
Capture Locks on the first
By depsci in forum Newbie / General discussionsReplies: 4Last Post: 2nd May 2008, 14:21 -
Brightness fluctuation problems - capt from VHS thru ADVC110
By ChrisMtl in forum Capturing and VCRReplies: 18Last Post: 7th Dec 2007, 13:47
