I recently converted a Divx movie to SVCD using the guide provided on this site. I used tmpgEnc and Virtual Dub. I burned it with Nero. All the conversion and burning went without a hitch, but when I play it on my standalone DVD player (Raite 675), the colors go constantly from black to white and then to color. This happens throughout the movie. I would appreciate any help.
After you used TMPGENc and you got the mpeg, does that play ok ? If not try this;
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
Also, if you have the SMR codec installed, un install it, and install the Nimo codec pack instead, this make sure the right codec is being used. -
Does this happen if you play the movie on your computer?
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 19:31 -
How to edit these colors?
By ashkan_vpm2 in forum SubtitleReplies: 0Last Post: 15th Jul 2010, 07:29 -
weird colors. VCR gone bad?
By damnidunno in forum Capturing and VCRReplies: 1Last Post: 29th May 2010, 12:16 -
Weird subtitle colors when authoring a DVD
By dexter30 in forum SubtitleReplies: 4Last Post: 22nd Feb 2010, 22:54 -
TV Safe Colors ?
By Mike99 in forum Authoring (DVD)Replies: 31Last Post: 13th Nov 2008, 04:01
