How do i convert MPEG1 to MPEG2?
The reason is that i have a 800.MB MPEG1 file, but to get it fully on a CD i have to make S-VCD ISO.
VCDEasy only supports MPEG2 files for making an S-VCD image so i need to convert the MPEG file first.
Which program is recommended?
Results 1 to 19 of 19
an 800Mb mpeg-1 file, if it is fully VCD compliant, will fit on an 80min CD-r, no need to convert to mpeg-2.
If you do convert to SVCD, it will get bigger due to higher resolution and bitrates, but will look no better and possibly worse, and as its bigger, still won't fit on one CD-r! -
No, unless you reencode from a good source, taking a so so MPEG1 you'll get at best a so so MPEG2. You can't make a diamond from a lump of coal with your hands.
Panasonic DMR-ES45VS, keep those discs a burnin' -
I saw Underdog do that once, but he needed to take a little energy pill first. At any rate, I was always skeptical about that.Originally Posted by kittyAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
the thing is, i got a pretty good qual black hawk down in divx. i converted it to mpg1, and burned it as a vcd. it looks pretty good, but i was wondering if i converted it to SVCD would it atleast look a little better because of the SVCD resolution?
Thanks for the info.
Reply to last topic.
You will get a little better picture if you convert Divx to S-VCD.
I have converted several good MPEG 1 files to S-VCD and they look good.
On PC you won't see that difference, but on a real DVD player you will notice it. -
faraq, if i may ask what did u encode to mpeg2?
so for sure if i encode it to mpeg2, i WILL notice the difference on my dvd player? -
Why not just encode from Divx to SVCD instead of VCD to SVCD. Now thats an idea unless you deleted the Divx.
If you want to go from vcd to svcd and have the original divx file then here is something to consider:
One reason you may want to go back to the DIVX is the framesize may be larger. I got some great divx that someone compressed at 704x480 and I was able to convert to 2 cd vcd and svcd. My player accepts the 704x480 so I do not have to change the frame size unless file size is an issue (which it isn't so far on 2 cd). Many create their vcd 352x240 thereby losing something in the process. If you have such a vcd it pays to go back to a better divx.
Another reason is the compresion rate. The divx may be compressed at 3000 or better while the vcd may be 1150 if its compliant.
Also you may have applied filters that you may want to reapply with the new size and compression otherwise they may have a more significant effect on your video.
You may also want to change your audio options
Another trick for svcd is to try 352x480 instead of 480x480. It works on my player and saves file space if you need it.
Before someone comments: Technically my files are xvcd and xsvcd. -
no i dont have the original divx file, but i have thedat file from the vcd itself.
We now know that you don't have the divx so all you want to do is convert from mpeg1 to mpeg2.
Your logic and file size still puzzles me. I cant believe that converting to svcd will result in a file size that you will fit in the same space as a vcd.
The mpeg2 will require a faster bitrate and more than likely a larger framesize. Can't you just create the vcd from nero. 800 mb should be ok.
Since you have a dat file. Where did you get it . Is it still on a vcd? then all you would need to do is CDCopy. -
gll99, d00d i knw what to do, all im asking is, is it worth it? will converting it, make it look ALOT better?
In your case I would say not that you would notice and the file would be larger.
If it seems better its because you increase the bitrate to create an svcd but you can do that with an mpeg1 also.
As I said if you still had a top quality AVI then I would say go for it.
Now what I say is subjective. If you have time, need to be convinced and want to play with it then go for it.
No matter what the results are it won't prove a thing for anyone else just for you. Even if you came back and said wow look how great it looks. It could all be because of how your standalone DVD player interprets mpeg1 and mpeg2 signals. These areas are personal taste and may even be qwirks of our own equipment. A smoothed image may look great to someone because it has no noise but to anothet the loss of detail is not worth applying an image smoother. See its personal taste. That's why so many opinions.
Now! Problem solving, helping someone achieve an objective, offering alternatives or other options and helping to explain results. That's the fun!
Myself, I would do something else. There are too many other tricks to try.
Wow just read all the posts and see how much fun people are having. -
thanks for all the info gll99. yeah i didnt think it would make much of a difference, but farao was like, yes u can tell the difference in a dvd player. well i probably just stick with XVCD on this one.
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 19:39 -
remuxing mpeg1 audio to mpeg2
By ChaosOrb in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2009, 15:25 -
Question about which is more clear, mpeg1 or mpeg2?
By jimdagys in forum Newbie / General discussionsReplies: 12Last Post: 25th Sep 2008, 02:08 -
Burned an MPEG2, replicator says it's MPEG1 and unusable?
By First1 in forum Authoring (DVD)Replies: 4Last Post: 11th Nov 2007, 14:55 -
Mpeg Streamclip_DVD to Mpeg1 or Mpeg2
By edit204 in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2007, 11:58
