Attempting to convert avi to vcd, but cannot extract the audio. Both VirtualDub and TMPGEnc Plus do not seem to support. TMPGEnc wont even load the audio and Virtual Dub wont save it (audio compression not compatible with input format). Virtual Dub reports an Unknown Compression in File Info. Interestingly enough, virtual dub will save it in direct stream copy but not full processing mode.
The avi file plays fine in WinMedia Player so all the latest codex should be present.
Any advice would be appreciated
Thanx![]()
Your audio is AC3 or some other format not supported by vdub. Save in direct stream copy mode and convert to wav or .mp2 with Besweet or Headach3e, whichever one works for you.
Hope this helps
DTS-HD Master Audio Extraction from Tsmuxer
By m1ke486837 in forum Blu-ray RippingReplies: 0Last Post: 5th Jan 2011, 20:29 -
MP4 audio extraction (ripping the 5.1)?
By takearushfan in forum AudioReplies: 15Last Post: 13th Sep 2010, 09:12 -
Audio extraction from DVD using VirtualDubMod
By Ogilvy in forum AudioReplies: 4Last Post: 29th Mar 2010, 16:56 -
MP4 Audio Extraction
By neumannu47 in forum Video ConversionReplies: 2Last Post: 28th Aug 2008, 20:17 -
5.1 audio channel extraction
By efiste2 in forum AudioReplies: 3Last Post: 15th Sep 2007, 05:05
