My 74 minute CDRs are stamped "650mb" on them. My 80 min CDRs are stamped "700mb" on them. But I've seen referenced to burning 700 and even more onto a regular CDR, without overburning.
I think it relates to the format you use ISO, UDF, type 1, type 2, ... but I don't understand the implications of choosing these options.
Which options gives the most storage on a CDR, without requiring Direct CD or something similar installed on the computer?
Thanks for any information demystifying this.
74 min/650MB CD-Rs will hold 74 minutes of CD-audio or video-CD format video. Those formats have a less robust error correction, so more space is available to store video/audio data. They will hold 650 MB of data with stronger error correction. If your data were a program, you can't risk having any errors in it (the program may not work). Video and audio is more forgiving and the players themselves have compensation built-in for missing or garbled data. The same applies for 80/700MB CD-Rs.
A ripped audio CD track is about 10 megabytes per minute of audio. A 74-minute audio CD would have about 740 megabytes of audio data, which won't fit in the 650MB data format, but will fit in the audio CD format where strong error correction is traded for less correction and more space.
That's how I understand it; I'm sure others can give much more detailed information on the differences in error-checking techniques/theory, etc. -
Thank you , that helps a bit. If anyone can add more details re: what settings result in what CDR capacity, that would be helpful.
For example, does anyone know what settings to use in Nero to put a 720mb DivX movie onto a 74 minute CDR?
Could Laserdiscs hold non video data? - see James Bond license to kill pics
By yoda313 in forum Off topicReplies: 7Last Post: 16th Feb 2012, 18:42 -
German Scientists Transfer 700 DVDs of Data in One Second
By hech54 in forum ComputerReplies: 2Last Post: 25th May 2011, 13:45 -
Those discs which hold 25 - 50 GB of data.. are they worth it??
By SE14man in forum Newbie / General discussionsReplies: 7Last Post: 7th Nov 2010, 20:50 -
Help!! Can you create a DVD for both DVD player and hold data files for PC?
By musicalsolutions in forum Newbie / General discussionsReplies: 3Last Post: 7th Feb 2010, 07:32 -
How Can I burn a 90 min data CDR Image to HD Folder
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2008, 20:48
