I have down loaded movies from Kazaa. I am using TMPGEnc to convert
the movies. When I get to the 2nd step out of the five. A window pops up
and reads File"C:\program Files\kazaa\ My shared Folder\(smr) Scooby_
Doo - TS (1of2).avi" can not open, or unsupported. What do have to do
to fix this. Please help.
Do you have the smr patch installed? Are you able to watch the video on the same computer your trying to encode it on?
Originally Posted by mommy5
Also you should check the AVI for bad frames in Vdub, before TMPGEnc is used.
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 11:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 15:58 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 17:56
