Hey, I have a bin and a cue file for a SVCD, I've tried burning it in Toast as a disc image/CD ROM XA, but when I put it in my DVD player it doesn't come up as SVCD. It does show a pic/menu that tells me to press play, but when I press play it stops (I think the only reason I see this menu pic is because my Apex player can play raw jpegs?)..
Do I have to make an XML document for the bin to work, how do I write/make one?
Burning .bin SVCD images as XA should not work.
Use VCDToolsX. First VCDxRIP to extract the mpg, then VCDxGEN to create a .xml from the .mpg, finally vcdXbuild opening the .xml and obtaining two .img files. Burn these two .img as XA.
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
CLI to XML
By eon_designs in forum Video ConversionReplies: 1Last Post: 29th Apr 2010, 10:50 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
DriveImage XML
By blockie@sbcglobal.ne in forum ComputerReplies: 2Last Post: 25th Jul 2008, 16:25 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11
