After I ripped to VOB files, I use tmpeg to convert them to SVCD. But I notice Im getting the other languages also. It gives me a stutter effect... help![]()
Results 1 to 13 of 13
Use Smartripper 2.41 to rip in steam mode,this allows you to strip out all the foreign language tracks. What do you mean by stuttering are you frame serving in DVD2AVI?
I had that problem with a Disney movie
that's amulti-angled film
do as wulf109 suggested use smartripper
it'll fix that problem -
I originally used SmartRipper to get the VOB files, but how does stream work? It gives that stutter effect since it picks up 3 of the same frames but in different languages.
When you open smartripper choose stream processing instead of input. check the stream processing box,files will appear. uncheck the files you don't want,highlight the video stream and and rip.
The stuttering is caused by how your encoding not ripping. -
I use smart ripper
and have never used the stream processing section of it for a multi-angled film
surely hope it works for him -
uhh noOriginally Posted by wulf109
the stuttering comes from the vob files
smart ripper is ripping all the angles of the film
hence giving him the other languages at the same time
he can be getting spanish english and maybe even french altogether -
Hello there try using DVD2SVCD very good program for ripping and converting to SVCD or VCD and with no problems
And if you want go to the site http://dvd2svcd.doom9.net/
or contact me at helio2k@hotmail.com -
I encode vob's in Tmpeg all the time without frameserving and never get stuttering. the only time I see stuttering is when I frameserver thru DVD2AVI. In my humble opion it's frameserving that causes problem in Tmpeg,not Tmpeg.
it's not the frameserving the issue on stutteringOriginally Posted by wulf109
if the stuttering problem comes from the multi language
maybe I'm understanding wrong -
You may be confusing what angle means. Angle in ripping just refers to the movie file you want to rip. Angle on a DVD refers to multangle viewing of the DVD on your DVD player. Very few disks actully use multi-angle.
yep very few use it
tho with multi-language
you'll get spanish english frames if the dvd isn't ripped properly
and they will play consecutively once it's ripped
I've had that happen with "Disneys The Jungle Book"
the beginning is where the title shows on a book cover and it went from English writing to Spanish right after
totally thru Me for a loop that first time
if geno325is is able to supply a sample of the ripped video we can see the exact problem
and give advice accordingly
Converting .VOB to MPEG-2
By PHNeedsHelp in forum Video ConversionReplies: 2Last Post: 21st Jul 2010, 13:22 -
Help with converting avi to vob
By music_freak in forum Video ConversionReplies: 1Last Post: 16th May 2009, 16:04 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15 -
Converting VOB to dv questions
By brewfeller in forum ffmpegX general discussionReplies: 2Last Post: 5th Oct 2007, 11:18 -
converting VOB
By gatefan810 in forum Newbie / General discussionsReplies: 7Last Post: 24th Jun 2007, 02:05
