Hi
After much deliberation and a littlemaths I have managed to get a VCD that plays well on my widescreen (16:9) television.
I have been using TMPGEnc for ages now and have always struggled to reduce the black bars such that when its played on my 16:9 tv, I get the correct aspect ratio for my conversion.
In the past I have used settings under video arrange method that are of the form "full screen (keep aspect ratio). This produce a movie that has the correct aspect ratio on a standard 4:3 tv, but when I place my tv in 16:9 manually, you end up with a very wide picture and everyone looks fat (so to speak).
I then realised that if I could make my converted file too high and all of the characters really thin ; on switching the tv to 16:9 the whole screen would be strecthed similar to playing an anamorphic DVD and hence I would end up with a very good picture in the right aspect ratio.
My movie was 640 x 272 which is as close as you can get to 2.35:1. I decided to turn into a std VCD of 352 x 240.
Working this all out the effective resolution of my image on my widescreen tv in 16:9 would be 352 x 4/3, which comes out at 469.333...
Hence my effective height would need to be 469.333 / 2.35 (original aspect ratio) which comes out at 199.
Hence in tmpgenc I set everything as standard for NTSC VCD and using a video arrange method of "Center (custom size). The custom size typed in is 352 and 199.
This results in a squashed up picture on a 4:3 tv but on switching my tv into 16:9 I get a really good picture in the right aspect ratio.
I decided to share this with everyone as I believe it makes life easier and who knows I could have made mistakes here. Please let me know if thats the case.
-Darren
Results 1 to 1 of 1
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 09:24 -
How to fullfill a widescreen video (4:3) into a widescreen project (16:9)?
By coxanhvn in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 12:59 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 14:22 -
Convert Pseudo Widescreen to Proper Widescreen
By simonw2008 in forum Video ConversionReplies: 5Last Post: 5th Apr 2008, 21:57 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 23:15
