Here is a problem with Microsoft XP and the AMD processor. Sounds like it may affect capturing, editing, and writing VCDs and DVDs.
DirectX 8.1 Programs May Stop Working on Computers with AMD Processors (Q321178)
The information in this article applies to:
Microsoft Windows XP Home Edition
Microsoft Windows XP Professional
SYMPTOMS
On computers with an AMD processor, programs that use Microsoft DirectX 8.1 may quit without displaying an error message. The same programs work correctly on computers with Intel processors.
CAUSE
The DrawIndexedPrimitive function stops working without displaying an error or debug message. This occurs because of a code error in the AMD-specific optimized code. This code error may lead to heap corruption.
RESOLUTION
A supported fix is now available from Microsoft, but it is only intended to correct the problem that is described in this article. Only apply it to systems that are experiencing this specific problem. This fix may receive additional testing. Therefore, if you are not severely affected by this problem, Microsoft recommends that you wait for the next Windows XP service pack that contains this fix.
To resolve this problem immediately, contact Microsoft Product Support Services to obtain the fix. For a complete list of Microsoft Product Support Services phone numbers and information about support costs, visit the following Microsoft Web site:
http://support.microsoft.com/default.aspx?scid=fh;EN-US;CNTACTMS
NOTE : In special cases, charges that are ordinarily incurred for support calls may be canceled if a Microsoft Support Professional determines that a specific update will resolve your problem. The usual support costs will apply to additional support questions and issues that do not qualify for the specific update in question.
The English version of this fix should have the following file attributes or later:
Date Time Version Size File name
06-May-2002 13:51 5.1.2600.44 1,180,672 D3d8.dll
STATUS
Microsoft has confirmed that this is a problem in the Microsoft products that are listed at the beginning of this article.
Published Jul 8 2002 8:01AM Issue Type kbbug
Last Modifed Jul 8 2002 8:01AM Additional Query Words
Keywords kbWinXPpreSP1fix
Here are some quick links just in case you don't feel like being charged for calling Micro$oft.
http://www.amdmb.com
Windows XP Hotfix Q321178 DirectX Update for AMD (07/18)
or jump directly to download the patch
http://www.warp2search.net/download.php?op=viewdownload&cid=3 -
How nice of Micro$oft to charge you for something that fixes a product of theirs that was broken to begin with.
It's sort of like buying that new DVD player, finding out that the composite cable plug wasn't connected inside, and then having the company charge you to fix it.
You gotta love it, no?
Ex-AMD engineer rips AMD management
By deadrats in forum ComputerReplies: 0Last Post: 17th Oct 2011, 18:39 -
the new AMD "Fusion" processors are out
By deadrats in forum ComputerReplies: 2Last Post: 2nd Jul 2011, 20:27 -
Does Final Cut Pro not support AMD processors?
By jeanpave in forum EditingReplies: 8Last Post: 27th Sep 2010, 03:03 -
How many processors do I have
By hungledink in forum ComputerReplies: 4Last Post: 20th Aug 2008, 03:46 -
AMD 64 4000+(1x2.4GHz) or AMD 64 X2 3800+ (2x2.0GHz)
By neomaine in forum ComputerReplies: 19Last Post: 13th Jul 2007, 10:24
