How can I rip my DVD's and convert them to CVD?
How does I know if my DVD Player is compatible with CVD format?
There is a guide on how to do this on the front page of this site..
However, in a nutshell, rip your DVD as if you were ripping to SVCD, but change the horozontal resolution to 352 instead of 480.
As for compatability....if your DVD player will play burnt CD's it should have no problem reading CVD as the mpeg file used is DVD compliant.....mostly....you will have to change the audio sample rate to get a truely DVD compliant file but for the most part you should be able to leave it as-is.
Have fun...
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 08:30 -
Anyone mirrored or saved OGT/CVD subbed test images?
By zinchronized in forum Newbie / General discussionsReplies: 5Last Post: 11th Aug 2010, 22:46 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 07:55 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 20:28 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 12:13
