Hi, i need some help.
I want to capture in virtualdub using the VFW Huffyuv codec. I have already installed Huffyuv v2.1.1 and i'm using it with other capture tools but in virtual dub when i select Video->Compression, i don't see any of the VFW codecs.
Anybody knows whats going on?
My OS is Windows XP and my capture card is AVERTV.
Thank you
Seems like VDub has problems with vfw under XP. Make sure you selected a compatible color format like YUY2 or 24bit... hope it works!
Otherwise use WDM drivers.
emale, how do you even get vitualdub to recognize your AverTV? It won't recognize mine and I heard they are compatible (at least yet).
Possibly the cap card is running WDM drivers? I didnt do the research
for you, but something to look for.
I dont think Huffyuv is limited to VFW, but it may be, I dont recall...
Been a long time since Ive fooled with analog equipment. 8)
VirtualDub being stupid (VFW codec...)
By Katsu-kohai in forum Video ConversionReplies: 20Last Post: 13th Jun 2017, 13:53 -
Looking for a conversion software that uses Dshow/VFW/ACM codecs
By giuliojiang in forum Video ConversionReplies: 2Last Post: 9th Jul 2010, 09:28 -
VirtualDub x64 with ffdshow vfw x64 no H264
By SandyB in forum Newbie / General discussionsReplies: 8Last Post: 10th Aug 2009, 18:45 -
Making 32-bit VFW-ACM codecs available to XP 64-bit Edition.
By gastorgrab in forum EditingReplies: 5Last Post: 19th Aug 2007, 12:12 -
what is the best codecs to use in virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 4Last Post: 9th Jun 2007, 08:16
