Hi Guys
I've been trying to convert a high qiality Divx of the 13-Ghosts film to VCD format.
The original Divx file had a problem whereby 58mins into the film the audio shifted by nearly a second.
Using TMPEnc I split the file into 2, and adjusted the audio by -750ms in the second part.
I then used TMPEnc to join the 2 files together and the movie now plays fine on my PC.
The file size of the file is 778MB and I'm using VCDEasy to burn a VCD in the normal way to an 80Min CD.
The problem is that although the original TMPEnc'ed file is only 778MB, VCD Easy reports that the VCD file will be >900mb and so won't fit onto a single CD.
Any ideas why this has happened as when I originally burnt the uncut/joined image to CD it fitted fine (But had the audio shift in the second part of the film). It's only since I cut & joined the file that VCD is reporting the increase in file size.
Any help greatly appreciated![]()
Awwww....come on guys, I vcan't be the only person who's had this problem.......or am I ?
VCD format = 10Mb per min, if you want it smaller, use a lower bitrate when encoding. This then produces an XVCD (non-compliant VCD) and it will also lose some quality.
Hi there
Many thanks for the reply.
The original burn I did was fine, and fitted onto 1 x 80min CD, so the bitrate is ok.
the probs appeared since I split the file in 2 and then rejoined.
After conversion with TMPEnc the file size is still fine (778mb) so in theory it should fit fine to an 80min CD, but when I use VCDEasy the VCD image then goes up to over 900mb.
I've thought about re-encoding the whole filr again - but would this ruine the quality as it would then have been converted twice ?
Cheers -
Your problem may have caused by "padding"
Check out this tread for more info.:
http://forum.vcdhelp.com/viewtopic.php?t=98450&highlight=padding
You may solve your problem by reading this tread:
http://forum.vcdhelp.com/viewtopic.php?t=78738&highlight=webster
Webster
What do you think??? Maximum Quality/Low File Size DVD conversion
By iqbal88 in forum DVD RippingReplies: 6Last Post: 7th Aug 2011, 02:48 -
Default window size for video file changes after conversion.
By dodo23 in forum Video ConversionReplies: 7Last Post: 25th Aug 2010, 18:26 -
wma to mp3 errors; losing file size on conversion
By gidget00 in forum ffmpegX general discussionReplies: 1Last Post: 22nd Aug 2008, 18:48 -
Video Conversion - output file size
By Leo48 in forum Newbie / General discussionsReplies: 2Last Post: 19th May 2008, 07:28 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
