Hi I'm new to all this so I read the instructions for converting AVI, DV, DivX, ASF, MOV, nAVI, SMR, WMV to VCD MPEG at http://vcdhelper.com/tmpgenc.htm
After converting my .avi file, I found that there was no sound so I went on to read 'How to convert the audio in a video to a wav' at http://vcdhelper.com/virtualdubaudio.htm
Downloaded Virtualdub, followed the instructions, tried to save the WAV but I get the errors 'ACM failed to suggest audio decompression format' and 'AVIOutputWAV: The handle is invalid'.
So I downloaded dBpowerAMP Music Converter and tried using it, but it goes 'Select Music File(s) To Convert' and my .avi file isn't on the list.
What do I do now? How can I convert the audio in my .avi file to a .wav file?
Any help is appeciated!
They way that I do DivX to WAV, is as the audio is compressed in divx ,virtual dub say it can not handle the "save as wav".
So using the decompress tool that comes in AVI2VCD, run the avi though that (3-4mins) then load the new avi that it creates into virtual dub and click "save as wav"
Seem to work a treat, may not be the quickest way of doing it, but it works.
Paul
Problem converting .ts file - no video (only audio) detected!
By guy24s in forum Video ConversionReplies: 2Last Post: 29th Aug 2011, 18:57 -
Dilema ? Problem when converting video with audio track
By doward in forum ffmpegX general discussionReplies: 5Last Post: 1st Dec 2010, 13:32 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 12:38 -
Converting .FLV audio to .WAV
By socool135 in forum AudioReplies: 1Last Post: 20th Feb 2008, 19:24 -
Audio problem with WAV files
By vertical in forum Newbie / General discussionsReplies: 5Last Post: 8th Jul 2007, 17:47
