I was recently considering purchasing a SB Live Extigy to install on my PC that I use for VCD captures. What I was wondering was if 1) Because of its USB hookup, if I would have any problems with audio/video sync. or 2)If anyone has a SB Live Extigy that they capture with, if they have any problems, and if they use classic USB or USB 2.0. I'm worried that because of the much slower usb, it will lag behind the video coming in off the PCI bus. I figure that USB 2.0 wouln't have that problem, but then there is the matter of CPU usage for the USB bus. Any thoughts or suggestions would be greatly appreciated.
Thanks in advance.
i am using a ADS USB Instant DVD with a Creative SoundBlaster Extigy
i have them both connected directly to seperate USB ports on the computer (no hub!), and capturing works fine. no sync issues.
(disregarding the headache of setting up the AUID with its known sync issues. but they are now resolved)
Help capturing video
By carbongixxer in forum Capturing and VCRReplies: 1Last Post: 2nd Aug 2010, 18:21 -
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 06:37 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 14:16 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 09:49 -
Capturing in HD
By The Sumerian in forum Capturing and VCRReplies: 1Last Post: 7th Jun 2007, 11:40
