Ok i have sucessfully burned my first vcd. Couple questions. Am i right in saying that you can never get a video better than the source file?
Also is svcd better than vcd?
And finally when i burn from a source file i am sure its best to keep the file the exact same size. It seems like when i burn a divx file to vcd when i play it the picture viewing area is bigger and the resolution looks to be slightly less than the source. How when i convert can i make it the exact size of the source file so that doesn't happen again?
Yes, your right, you cannot get better quality than the source.
Yes, SVCD is better than VCD.
If you want to keep the same resolution as your source, you will be moving outside of VCD standards and the VCD might not play on your DVD player. VCD standard resolution is 352x240, any other resolution is outside of vcd standards. But, if you chose to keep the same resolution as your source, then in TMPGEnc, simply hit the settings button and the resolution is located near the top, change it to your desired size and click ok.PlaiBoi -
You will never get better quality than the source, though some filter settings might be able to make the experience slightly more pallateable. If the original video is fuzzy, out of focus, you will never get it crystal clear. However, you can make it slightly less fuzzy with a Sharpen filter. Perfect? No. Better? Maybe.
Yes, SVCD is better than VCD - IF your video is encoded at 3000 kilobits per second or higher. Under 2500 kilobits per second MPEG1 often looks just the same or better (at the same resolution). If your source video is poor to begin with, there is no need to bother with SVCD, no matter the bit rate. If you don't mind using multiple discs, or allowing for much longer encoding times, SVCD is excellent.
Remember, the TMPGEnc Setting dialog will "stick" to the tab you last used. Setting | Video | Video stream editing | Size will allow you to change the resolution of the output file. Setting | Advanced | Video arrange method | Center (custom size) will allow you to adjust the visible area within the output. Setting | Advanced | Clip frame also offers options for cropping and masking the original video. It may take some experimentation to get the desired results.
Unta Glebin Gloutin Globin,
Akai Rounin, The Cyber Sage
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 22:30 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 02:18 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 06:56 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 18:33
