Any software can i used to edit a mpeg file and export to mpeg?
i want to add some transitions and adjust the brightness of my mpeg1 clip, i have adobe primere, but it seem only can export the movie to avi...isn't it?
MSPro 6.5
"OO"
ps: if you are encoding these files from a cam or VHS or whatever, encode them using Virtual Dub and tweak the brigtness (+many more options) at the first encoding, then edit under MSPro....P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo -
Use the MPEG tools in TMPGEnc to join and cut MPG files. (There are other programmes to do this with more accuracy than TMPGEnc, but I still use it a lot if the edit points are not critical.)
You can also reprocess a MPG1 or MPG2 file in TMPGEnc. If you want to change the brightness, go to SETTINGS, ADVANCED, check SIMPLE COLOUR CORRECTION, double click on SIMPLE COLOUR CORRECTION and adjust the slider bars to the desired level.
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 15:55 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 11:05 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
How to Edit MPEG with VDubMod and save as MPEG?
By DVFun in forum EditingReplies: 11Last Post: 3rd Nov 2009, 15:32
