Hi-- do programs really make a difference, I've tried 3 capture programs and still get a lot of dropped frames.. Do you think trying AVIO will make it any better? If so, where can I find it, and also how do I enable DMA (and what does that do)? Thanks
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Yes, programs make a difference.
Here is AV_IO homepage
http://www.nct.ch/multimedia/avi_io/
I don't know about DMA (actually I do, but I can't think now -_- zzz)
I usually get about 30-40 dropped frames/hour. I actually got more dropped frames with AVI_IO than I did with Vdub. I think all of my dropped frames are due to synch issues. I have a 1.2Ghz Athlon with 256DDR Ram and an empty ATA100 60GB HDD and I get dropped frames even when capturing at 352x240. If I had a better soundcard I would probably not get dropped frames.
If you are getting 30-40 dropped frames per hour on a 1.2 GHz Athlon with an empty 60GB drive, you probably have some active background tasks running.
You should look into optimizing your computer system for capture.
I have a 1.4 GHz Athlon with an empty 60GB drive and 512Mb of DDR RAM. I usually get less than 2 drops per hour using the fastest lossless capture mode of the Huffyuv codec. 640x480 on a BT848 TV card (mono sound at 64kbps)
Help me find the right solution please.
By abeaty in forum Video ConversionReplies: 8Last Post: 7th May 2010, 23:12 -
find the name of this movie
By canadateck in forum Off topicReplies: 3Last Post: 22nd Jan 2010, 18:55 -
has anyone find out what the problem is?
By suav3sito in forum SubtitleReplies: 0Last Post: 12th Aug 2008, 15:28 -
Where to find SUBSYNCH
By Wan Dat Ting in forum MacReplies: 3Last Post: 18th Jul 2008, 20:15 -
Cannot find subtitles
By vertical in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jan 2008, 18:26
