I am new to all of this, and as I was browsing around the site I noticed that every page said that VCD's video stream had a fixed rate of 1150kbps. Now I know a standard 650MB cd can hold 70 something minutes, but can I lower the bit rate to say 650kbps and still get it to run on a DVD player? I understand quality problems, but I want to look at this option.
Andrew
Sure, but it ceases to be a highly-compatible standard VCD, and instead becomes a less-compatible non-standard XVCD. Check out that "What is VCD" link up there on the top left. Some stand-alone players have superb XVCD compatibility, and some do not.
If your player supports it, the advantage of XVCD is that it allows you to use VBR encoding, generally resulting in smaller file size at the same video quality.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Ok. I think your opinion is enough. I should stick with the regular VCD to ensure that it would work. I reckon that if the movie is above the capacity I could always split it up onto 2 cd's. And I wouldn't be wasting the 2nd cd, I guess I could find something else related to the movie to fill up the rest of the 2nd cd.
Thanks for helping me. I already looked at the What Is VCD, but I took another look.
Andrew -
how long is the movie you want to fit to 1 cd? you should be able to get just under 80 minutes on an 80-minute CDR at the VCD standard template.
if your movie is 83-84 minutes or a couple of minutes more, if you change the audio bitrate down to 128kbps, you'll be able to fit a bit more on the disc.
try this guide..
the newbie's guide to fitting a movie on 1 CD with tmpgenc
of course the best thing to do is encode a couple of minutes of the file first, then cancel the encode, and burn it to a CDR-W and test it in your DVD player.
if it works.. go ahead and convert the whole thing.
MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free -
Well, the movie is 102 minutes. But when I tested it--I have Roxio VCD Creator--it said something about compatibility about the audio at 160kbps and I left it at 224 and quit out.
by the way--I have experience with TMPGENG, which is what I made the Mpeg-1 conversion with. -
Originally Posted by greenmist06As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Youtube changed my colors! What to do?
By thurnau in forum Video Streaming DownloadingReplies: 53Last Post: 8th Feb 2011, 13:18 -
VCD vs Half-D1 vs Low bitrate full-D1
By nharikrishna in forum Authoring (DVD)Replies: 44Last Post: 6th Feb 2011, 22:50 -
Things have changed
By Marco33 in forum Off topicReplies: 13Last Post: 23rd Dec 2010, 21:29 -
Tool for VCD at 2500 bitrate with No Re-encoding
By whenloverageswild in forum Authoring (VCD/SVCD)Replies: 21Last Post: 6th Mar 2009, 11:34 -
WMP changed
By KLouis22 in forum Software PlayingReplies: 5Last Post: 5th Dec 2008, 07:36
