I converted an avi (divx) file to MPG using TMPGenc (NTSC SVCD option) and burned the mpg to a SVCD (Nero 5.5.3.5). When I play the CD on my Panasonic A160 DVD player, the image is perfect but there is no sound. Anyone has an advice ??
PS : when I play the resulting mpg file on my PC (before burning with Nero), I have both sound and image.
<font size=-1>[ This Message was edited by: CallMeJack on 2001-08-08 23:20:08 ]</font>
Your source file probably has an audio sampling rate of 48000 Hz - you need to convert the audio stream to 41100 hz (use virtualdub)
Cheers
Buzzrick -
Buzzrick :
aarrghh, didn't work, still no sound ! but we might not be sor far : with Virtualdub, I tried to extract the wav in 44100 hz format. I could change all the parameters except that the bit rate was 173k/s and not the 224k/s which i suppose is the standard for SVCD. Do you think this could be the reason it didn't work ? how can I set the bit rate to 224K in Virtualdub ?
mpg to avi result no sound
By fnietoelgazi in forum ffmpegX general discussionReplies: 12Last Post: 24th Dec 2010, 12:45 -
no sound when playing mpg file
By hussains in forum Newbie / General discussionsReplies: 1Last Post: 31st Mar 2010, 04:59 -
Why does this mpg file doesn't play sound in my divx player?
By Stealth3si in forum Newbie / General discussionsReplies: 15Last Post: 5th Jul 2009, 20:00 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50 -
TMPGEnc not working.. what else is good for avi to mpg?
By andre477 in forum Video ConversionReplies: 10Last Post: 21st May 2007, 02:52
