  1. Hi !
    I reencoded some video clips to CVD-format.
    Now I want to put them on CD for storage reason to
    put them finally on DVD as the standard (-/+) becomes obvious.
    Here is my question:
    How can I assure that my converted CVD clips are REALLY
    CVD/DVD compatible. Is there a prog that examines my clips
    and tells me that they are DVD compatible for sure?
    Like Nero checks VCD/SVCD clips if they are compatible
    (properly encoded) when making VCD/SVCD.
    Greetinx
    Med.
  2. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    NERO can also burn DVD's, so I assume that NERO will check this for you.
    Did you leave the audio part at 48KhZ? That's DVD standard.
    The Dutchman
  3. so long as the video resolution is 352x480/576 and you don't exceed 15 frames per gop(for pal)and 18 frames per gop(forntsc),then you'll be o.k
  4. Thanks for your reply!
    I suppose Nero would check my CVD-clips but unfortunatly I can't
    select DVD...maybe because I still have no DVD-Recorder...
    352*576, 48k Audio, 15frames/gop. max. 2520kb/s
    I hope I did everything right but I woul like to be sure though
    Any suggestions are very welcome!
    Med.
